Build process suddenly fails
Hi,
I got from now to then a strange message from the build process. How can I debug that? What is missing? Any hints? If I switch temporarily to other watchfaces or widget the build process works fine :-(
BUILD: C:\Program Files\Java\jre1.8.0_161\bin\java -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar D:\Downloads\Connect-IQ-SDK\bin\connectiq-sdk-win-2.4.4\bin\monkeybrains.jar -o "\\NAS\Documents\Eclipse\Workspace\Colors\bin\Colors.prg" -w -y "\\NAS\Documents\Garmin\developer_key" -d fr935_sim -s 2.4.0 -f "\\NAS\Documents\Eclipse\Workspace\Colors\monkey.jungle"
BUILD: ERROR: Das System kann den angegebenen Pfad nicht finden
BUILD: java.io.IOException: Das System kann den angegebenen Pfad nicht finden
BUILD: at java.io.WinNTFileSystem.createFileExclusively(Native Method)
BUILD: at java.io.File.createNewFile(Unknown Source)
BUILD: at com.garmin.monkeybrains.Monkeybrains.writeDebugXml(Monkeybrains.java:331)
BUILD: at com.garmin.monkeybrains.Monkeybrains.runPRGCompiler(Monkeybrains.java:1427)
BUILD: at com.garmin.monkeybrains.Monkeybrains.compileApplication(Monkeybrains.java:1039)
BUILD: at com.garmin.monkeybrains.Monkeybrains.run(Monkeybrains.java:2458)
BUILD: at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:270)
BUILD: at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:253)
BUILD: at com.garmin.monkeybrains.Monkeybrains.main(Monkeybrains.java:299)
BUILD: usage: monkeyc [-a <arg>] [-b] [-c <arg>] [-d <arg>] [-e] [-f <arg>] [-g] [-h
BUILD: <arg>] [--hideApi <arg>] [-i <arg>] [-k] [-m <arg>] [-n <arg>] [-o <arg>]
BUILD: [-p <arg>] [-r] [-s <arg>] [-t] [-u <arg>] [-v] [-w] [-x <arg>] [-y
BUILD: <arg>] [-z <arg>]
BUILD: -a,--apidb <arg> API import file
BUILD: -b,--buildapi Build API output files
BUILD: -c,--configs-dir <arg> Configuration directory for each device
BUILD: -d,--device <arg> Target device
BUILD: -e,--package-app Create an application package.
BUILD: -f,--jungles <arg> Jungle files
BUILD: -g,--debug Print debug output
BUILD: -h,--excludes-map-file <arg>Mapping file of exclusions
BUILD: --hideApi <arg> Hide API annotations
BUILD: -i,--import-dbg <arg> Import api.debug.xml
BUILD: -k,--write-db Write out the api.db file
BUILD: -m,--manifest <arg> Manifest file
BUILD: -n,--api-version <arg> The new API version
BUILD: -o,--output <arg> Output file to create
BUILD: -p,--project-info <arg> projectInfo.xml file to use when compiling
BUILD: -r,--release Strip debug information
BUILD: -s,--sdk-version <arg> SDK version to target
BUILD: -t,--unit-test Enables compilation of unit tests
BUILD: -u,--devices <arg> devices.xml file to use when compiling
BUILD: -v,--version Prints the compiler version
BUILD: -w,--warn Show compiler warnings
BUILD: -x,--excludes <arg> Add annotations to the exclude list
BUILD: -y,--private-key <arg> Private key to sign builds with
BUILD: -z,--rez <arg> Resource file
BUILD: Complete
Aborting launch due to failed build.
  • Could be your nas? Try your local storage and see if the problem occurs there.
  • Hi Peter, I don't think that the NAS is the problem since the other watchfaces and widgets still work and are also located there
  • The build command contains 5 paths, simply check every one of them if the referenced file is in place. Also check if the contents are valid.
    Bye
  • I can't get it running. I checked every single path:
    1. C:\Program Files\Java\jre1.8.0_161\bin\ --> is there, including the java.exe
    2. D:\Downloads\Connect-IQ-SDK\bin\connectiq-sdk-win-2.4.4\bin\ --> is there, including the monkeybrains.jar
    3. \\NAS\Documents\Eclipse\Workspace\Colors\bin\ --> is there - the prg file is missing
    4. \\NAS\Documents\Garmin\ --> is there including my key file
    5. \\NAS\Documents\Eclipse\Workspace\Colors\ --> is there inclunding the jungle file
    Any further hints?
    Furthermore I found during my work on colors a failure on this website: click
    The color map ( https://www.dropbox.com/s/3oub3q80vv1hh7w/colors.JPG?dl=0 ) contains two wrong numbers which have to be 0x55FFAA and 0x55FFFF. Where can I report this issue?
  • Can you please check, if file creation is possible in the folder where the prg-file is referenced? Because the build process should place this file there in the build process.
    Bye
  • Thanks for that. This was the problem: The directory was not writeable any more. I had to delete the directory and create it newly as admin. And voila. It works again.
