Garmin Connect Mobile does no longer allow to clear settings
  • A Descriptive Title (e.g. "Simulator Freezes Launching App in Eclipse")
Garmin Connect Mobile does no longer allow to clear string values in the settings
  • The Environment:
Garmin Connect Mobile 4.3
  • A detailed description of the issue
This used to work before, but when trying to clear the text in Garmin Connect Mobile a exclamation mark is now shown, it works to clear the setting in Garmin Express.
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/s7.postimg.org\/yukmptlcr\/2018_04_04_17.08.29.png"}[/IMG2]
(Although it's the default, in this case I've also tried to explicitely set required="false" on the settingConfig but this does not change the error)
<setting propertyKey="@Properties.alarm2Text" title="@Strings.alarm2TextTitle">
<settingConfig type="alphanumeric" required="false" />
</setting>
  • Steps to reproduce the issue
Example app to reproduce: https://apps.garmin.com/en-US/apps/7...c-3a5fa93376c3
Use Garmin Connect Mobile: Clear the value for alarm text 2 and save
  • Any applicable additional information
  • A code sample that can reproduce the issue (in email only if preferred)
