I am thinking about reducing memory load on the app by storing arrays/dictionaries in the object store when a view is getting hidden and retrieving them again when the view is put in foreground. For that I would like to clear this kind of cache on application load, that is why I wanted to iterate through all of them and delete the temporary data. But I guess this is also possible by using one dictionary for all views.
if to make arrey with your stored items name and make iteration throug arrey sending the names to clearing code?
(writing from phone, sorry if mistakes will appear)
//names should be as Str var NAMES["arr1", "arr2", "dict1"," dict2", "val1", "VAL2"]; //or by using arr langhe for dynamic for(var i=0; i<6; i++){ var removeStor = NAMES; App.Storage.setValue(removeStor, null); //or completely delete value: //App.Storage.deleteValue(removeStor); }
however, if i understud the idea correct, Sorage is based not in, lets say RAM, it's in HDD. So, by clearing Storage, you will do opposite, just will load RAM with extra functions..
The idea was another one. When pushing a particular view I want to push the data (that is currently in memory) to the properties (HDD) to spare some RAM. When the view becomes visible again, I want to push the data from HDD into RAM again.
