how can I simulate a wrist turn? There is a setting called sleep mode in the simulators settings but nothing happen. Is there a better way to test that?
for watchfaces in the sim, under "Settings", is "Low Power Mode". This is how to do the transition in and out of low power mode that you would see with a wrist turn (the onEnterSleep(), onExitSleep() calls)
The "Sleep Mode" setting, is actually for some older watchs (va, f3), where you could manually put the watch in a mode to record when you are sleeping, and there's a depreciated "isSleepMode" in the API which would change between true and false when you changed that, but that's all it does.
