I am creating a battery widget and would like to change the color from green to yellow to red as the battery drains. Does anyone know what values the Vivoactive 3 would use as thresholds for the battery icon color in the menu so that I can make my widget use the same values?
Not sure what they are on the va3, or if it's even common with other devices, but what you can do is use a watchface that displays the battery percentage, and when you notice a change from green/yellow/red, see what the percentage is. If it turns yellow and you see 47%, it's likely 50%.
In my watchfaces, I change at 25% and again at 10%
