Example of Vivoactive 3 style widget
I'm curious if anyone is aware of an example of a Vivoactive 3 style widget with the circular ring around the edge showing progress with the animations on the ring and digits. I've got a basic functionality using drawArc, but I would really like to add the animations and extra style.
  • You should be able to do the animations pretty easily with the WatchUi.animate() method. Here is an untested code snippet..
    // simple layout-compatible arc drawable
    class MyArc extends Ui.Drawable
    var radius;
    var color;
    var minimum;
    var maximum;
    var percent;
    function initialize(options) {
    Drawable.initialize(options);
    radius = options["radius"];
    color = options["color"];
    minimum = options["degreeMin"];
    maximum = options["degreeMax"];
    direction = options["direction"];
    percent = 1.0;
    function draw(dc) {
    dc.setColor(color, Gfx.COLOR_TRANSPARENT);
    var value = ((1.0 - percent0to1) * minimum) + ((percent0to1 * maximum));
    dc.drawArc(locX, locY, radius, direction, minimum, value);
    function setProgress(aPercent0to1) {
    percent0to1 = aPercent0to1;
    function setColor(aColor) {
    color = aColor;
    function setMinimumDegrees(aMinimum) {
    minimum = aMinimum;
    function setMaximumDegrees(aMaximum) {
    maximum = aMaximum;
    // your view class
    class MyView extends Ui.View
    hidden var arc;
    // assumes you have a layout that defines the arc as described in the Programmer's Guide here
    // developer.garmin.com/.../user-interface
    function onLayout(dc) {
    setLayout(Rez.Layouts.MyLayout(dc));
    arc = findDrawableById("arc");
    function setPercent(aPercent) {
    WatchUi.animate(arc, :percent0to1, Ui.ANIM_TYPE_EASE_IN_OUT, arc.percent0to1, aPercent, 0.5, null);
  • Thanks! That should get me started. I'll have to play around a bit and see what I can come up with.
  • Good news is that it works, bad news is that it is extremely slow in the simulator. Does the simulator accurately reflect on device performance?
