SDK 2.4.2 Eclipse Plugin: autocomplete doesn't show all API functions
MacOS High Sierra 10.13.3
Eclipse Oxygen.1a Release (4.7.1a)
Connect IQ SDK 2.4.2
The autocomplete feature is not showing all possible function of the SDK. For example, when I type "dc.getT", I get only "getTestObject" and "getTorqueEffectivenessPedalSmoothness" as suggestions. I was actually hoping to see "getTextDimensions".
I'm quite sure it worked better in other releases.
Cheers
    r.485,
    You are correct. We've already got a ticket tracking this from someone reporting this about color constants and discovered there were more. I've added this info to that ticket.
    Thanks,
    - Coleman
  • I downloaded the 2.4.3 SDK and the Eclipse Plugin. It seems that the autocomplete feature works a bit better now, but not yet as it was before. If you type "dc.draw", you see "drawLine" and "drawPoint" as a suggestion, but "drawText" isn't displayed. I'm quite sure it did on 2.4.1 and lower. I'm on MacOS High Sierra 10.13.3.
