Session.save displays "Failed" message on Fenix 5x.
I'm running the RecordSample test app which saves a walking session. I installed the app on my Fenix 5x, started recording the session, and then tried to save it. When I saved the session I received a "Failed" message from the watch. Also, nothing was saved when I looked it up on my Garmin account.
Any suggestions?
  • The "failed" is from the sync and not the app. The .fit file was saved to the watch, but there was an error sending it to Garmin Connect - maybe boarderline of BLE or wifi range? The .fit will be there under \activites on the watch, and show up in your history, and the .fit should be sent on the next sync.
    Awesome, thanks for the response - I found the .fit files. And as far as syncing with Garmin Connect goes ... I killed the app and turned on wifi (I was on mobile network before). After restarting the app .my activities synced. Thanks again!
