When users disable the Wrist heart rate monitor and start an App, a message is displayed "Wrist heart rate monitor is disabled" and pressing the start button does not work. How can I solve this problem.
I am the developer :) I can start native apps without problems, but my IQ App does not. If happens when I use Snsr.setEnabledSensors([Sensor.SENSOR_HEARTRATE,Sensor.SENSOR_TEMPERATURE]); When I disable Sensor.SENSOR_HEARTRATE no message appears. In this screen I don't fetch any heart rate data either. I just check if a heart sensor is available.
Which watch? That sounds like a message from the FW just to let the user know it's disabled when you try to enable it. Things should still work fine in your app.
Ok, I tried a couple of my apps on both the vahr and va3 with WHR disabled. I get the message that the WHR is disabled when I call setEnabledSensors(), but I clear it, and start recording, and don't see the message again. They run fine. It's my Hike2 in the app store if you want to try it.
Where/when/how often are you calling setEnabledSensors()?
