Request timed out when connecting over https to server with Let's Encrypt certificate
Hi,
As the title says, my vivoactive HR (FW version 4.3.0, widget built for SDK 2.4.x) gets NETWORK_REQUEST_TIMED_OUT when trying to POST to a server with Let's Encrypt certificate. If I configure the server to not use the certificate and run only on http, then makeWebRequest functions as expected.
Oddly enough, this only happens on the device; on the simulator, https with Let's Encrypt works fine.
Since on-device https connections do work in the WebRequest sample in the SDK, is this a problem with Let's Encrypt certificates? Can I load my certificate onto the watch somehow?
Thanks in advance!
  • Have you got the entire certificate chain loaded onto you web server? This was the problem I had for a long time before I worked out the problem, and the symptoms match. If you have only loaded the leaf certificate and do not have the intermediate certificate then you get a timeout.
    If you are using apache2, make sure you have SSLCertificateChainFile point to a file containing the Let’s Encrypt Authority X3 intermediate certificate found at https://letsencrypt.org/certificates/
    You are completely correct. I had been accidentally using only the leaf certificate. Appending the intermediate certificate to it resolved the timeout issue.
    Thank you very much!
