the response in onResponse(value) in Ui.ConfirmationDelegate with 920XT is reversed
Hi
In last firmware of 920 XT and in SDK 2.4.1 and in an application
in all my watches in class QuitDelegate extends WatchUi.ConfirmationDelegate
when you select YES the function onResponse(value) returns CONFIRM_YES and you make your action
and when you select NO the function onResponse(value) returns CONFIRM_NO All in fine and conform
In 920XT it's inversed
when you select YES the function onResponse(value) returns CONFIRM_NO
when you select NO the function onResponse(value) returns CONFIRM_YES
Why, can you fix this bug in future version
Thanks
Didier
    Hey,
    Sorry riedid74, I was able to do some testing on this. So I'm not seeing this. I think what might be happening is that some inconsistencies in the device Ui are causing confusion. For example, system menus highlight with white and scroll your option into the middle of the screen. Confirmation dialogues highlight with the native activity color. This is seen if you choose to discard an activity. This pops a confirmation dialog natively where the colored item is the one you have selected. Is this what you are seeing?
    Thanks,
    - Coleman
