Failed to connect to Simulator
Good Day everyone,
as the title already says I got a problem with eclipse not connecting with the simulator. Im on Mac. Any terminal input doesn't not work, the Simulator when started manually thou does. Eclipse also opens the blank Simulator. When I checked on it in the Mac console gives me the following message: 10759711: Error #17 (os/kern) invalid right attempting to shed send right on port ( port:59899/0xe9fb rcv:0,send:0,d:2 limit:0).
Any Ideas on what to do ?
Greetings Dazz
Edit: got it to work now after copying the sdk into the user folder so the terminal would find it, and the sudo running the simulator.
