Disabled steps, dist, and calories in simulator's edit activity monitor info window
I think topic is selfdescribed. I have newest Eclipse and newest plugin. Am I doing something wrong or there is a bug?
Fields are disabled only in Today row.
    AmebaWPanierce,
    You are seeing this correctly. It is not a bug. We try to simulate what is happening on the device. Typically those are things that happen dynamically throughout the day. If you set the steps per minute, click OK, select Simulation > Activity Monitoring > Fast Forward, then you can put in the amount of minutes to pass and click OK. You should see the steps new steps there. I don't think that the original design was meant for it to be so clunky. We can try and revisit this and see what can be done to provide easier access.
    Thanks,
    -Coleman
