I am trying to build a simple hello world application but I get a NullPointerException when trying to build/run it:
java -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar /home/otavio/tools/garmin/bin/monkeybrains.jar -o /home/otavio/code/garmin/hello-world/out/test/hello-world/hello-world.prg -w -y /home/otavio/Sync/Tools/garmin/developer-key/developer_key.der -z /home/otavio/code/garmin/hello-world/resources/layouts/layout.xml:/home/otavio/code/garmin/hello-world/resources/drawables/drawables.xml:/home/otavio/code/garmin/hello-world/resources/strings/strings.xml -m /home/otavio/code/garmin/hello-world/manifest.xml /home/otavio/code/garmin/hello-world/source/Hello-worldView.mc /home/otavio/code/garmin/hello-world/source/Hello-worldApp.mc -d square_watch_sim -s 1.2.1 --unit-test
ERROR: null
java.lang.NullPointerException
at com.garmin.monkeybrains.devices.SimDevice.<init>(SimDevice.java:12)
at com.garmin.monkeybrains.Monkeybrains.run(Monkeybrains.java:2383)
at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:270)
at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:253)
at com.garmin.monkeybrains.Monkeybrains.main(Monkeybrains.java:299)
usage: monkeyc [-a <arg>] [-b] [-c <arg>] [-d <arg>] [-e] [-f <arg>] [-g] [-h
<arg>] [--hideApi <arg>] [-i <arg>] [-k] [-m <arg>] [-n <arg>] [-o <arg>]
[-p <arg>] [-r] [-s <arg>] [-t] [-u <arg>] [-v] [-w] [-x <arg>] [-y
<arg>] [-z <arg>]
-a,--apidb <arg> API import file
-b,--buildapi Build API output files
-c,--configs-dir <arg> Configuration directory for each device
-d,--device <arg> Target device
-e,--package-app Create an application package.
-f,--jungles <arg> Jungle files
-g,--debug Print debug output
-h,--excludes-map-file <arg>Mapping file of exclusions
--hideApi <arg> Hide API annotations
-i,--import-dbg <arg> Import api.debug.xml
-k,--write-db Write out the api.db file
-m,--manifest <arg> Manifest file
-n,--api-version <arg> The new API version
-o,--output <arg> Output file to create
-p,--project-info <arg> projectInfo.xml file to use when compiling
-r,--release Strip debug information
-s,--sdk-version <arg> SDK version to target
-t,--unit-test Enables compilation of unit tests
-u,--devices <arg> devices.xml file to use when compiling
-v,--version Prints the compiler version
-w,--warn Show compiler warnings
-x,--excludes <arg> Add annotations to the exclude list
-y,--private-key <arg> Private key to sign builds with
-z,--rez <arg> Resource file
FAIL: 100
I tried a few different things, like running monkeyc directly with the same paremeters, but I got the same result. The source code for the hello world program is available here.
This is what I have installed:
$ monkeyc --version [16:32:12]
Connect IQ compiler version 2.4.1Unfortunately, the error information is not available and I cannot figure out what is going on. I am completely new to this SDK. Anyone has any idea what could be wrong?
