Menu-item: Use Label attribute instead of tag
I've upgraded onto SDK 2.4.1 and ran into the warning:
The label for the menu item "item_1" should be provided using the 'label' attribute instead of placing the label within the tag.
Using a tag instead of an attribute does not allow using variables! Which is bad :confused:
Works, only one localization file per language, which includes all my translations, somehow intuitive but raises the warning:
<menu-item id="item_1">@Strings.menu_label_Timer</menu-item>
The "new" approach, which makes one file per language necessary
<menu-item id="item_1" label="MyEnglishTranslation"></menu-item>
Really?!?
PS:
Both, Developer-Tools & Programmers Guide are teaching the "old" approach.
EDIT:
Even if Eclipse "thinks" that the variable/placeholder is now text, it still works!
<menu-item id="item_1" label="@Strings.menu_label_Timer"></menu-item>
So I take everything back and say the contray :rolleyes:
