I am trying to use the Attention module in a background process, but the simulator (SDK 2.4.1) throws an error that I need permission to do so. Now the question is, which permission do I need?
Depending on what you want to do, a possible way to get the attention from the user is via the requestApplicationWake API ( https://developer.garmin.com/downloa...nstance_method ). Unfortunately at the moment it's not really useful as it doesn't work properly on most devices (it does show a dialog box, but on most devices it isn't accompanied with a buzzer or beep, so if you're not looking at your watch you do not see it...).
I've got a ticket created for this here: https://forums.garmin.com/forum/deve...-buzz-nor-beep . It's not straightforward to fix as the problem is not located in the connect iq framework (so it's not a fix in one place), but it's a fix in the implementation of the api on each device (so resources need to be foreseen in every device team to fix this + a new FW-version needs to be released by each device team).
I am aware of this method but I was not sure if it signalizes to the user that something happend. If this is not the case (as you stated) it is useless for me. Will have to wait for a fix.
