Hello:
I'm trying to use UserProfile::getHeartRateZones() for an Edge 520 DataField project. The Edge 520 has three posibilities to set heart rate zones, i.e., puth the heart rate directly, as a percentage for the maximum heart rate and as a percentage of reserve heart rate (Karvonen formula). Which data is obtained via UserProfile::getHeartRateZones()? The API documentation says that an array with 6 values is returned, but which 6 values? If the % of reserve or % of max HR heart rate is configured, is the array of data the correspondent one?
On the other hand, I can't found a mathod to get the power zones, that can be configured in the Edge 520. Is there such method in the SDK?
Thanks
