You can download archives of the jpeg-ijg libraries directly from the Independent JPEG Group here
Our 3.0.x SDK uses an older version of wxWidgets that brings in this old library…
On Debian/Buster: one also need " libwebkitgtk-1.0-0" and "libjavascriptcoregtk-1.0-0" (which I haven't succeeded to "forward-port" from Strech yet)
Garmin: why don't…
I just installed the SDK on Bunsenlabs 64bit, I ran into these issues as well but I can not find the libjpeg8 package anywhere.
Any help would be appreciated because I really want to start developing :)
I think some linux folks just use the windows version in a windows VM under linux.
Our 3.0.x SDK uses an older version of wxWidgets that brings in this old library dependency. The 3.1.x SDK will likely depend on the libjpeg9c libraries.
thanks, I was able to compile the library and get the simulator running the example app :)
Garmin: why don't you release the required libraries in a "lib" folder in the Linux SDK ? (LD_LIBRARY_PATH would be our friend here)
