MAC : Simulator refuses to open
For some reason the simulator refuses to open, no errors!
I've reinstalled Eclipse IDE for Java Developers
Version: Oxygen.1a Release (4.7.1a)
Build id: 20171005-1200
OS: Mac OS X, v.10.13, x86_64 / cocoa
and the latest SDK, still no joy. Any ideas?!!?!
I've run THE SEE NO EVIL (whatever that is) and I see..
Couldn't connect to simulator.
Building project for 'd2bravo_titanium'... SUCCESS.
Running tests as 'd2bravo_titanium'.
Executing tests for entire project.
Building project for 'd2charlie'... SUCCESS.
Running tests as 'd2charlie'.
When I do run the actual connectiq project I see IQ app starting on the task bar then closing immediately.
In the mac system.log I see
Nov 3 21:57:59 MacBook-Pro com.apple.xpc.launchd[1] (com.garmin.connectiq.simulator.8400[6495]): Service exited with abnormal code: 255
This is driving me nuts!!!!!
    That log message is coming from xpc.launchd, which manages process to process communications and the associated privileges. I have not seen this issue before, but I am not a regular user of macOS. Does launching the simulator manually change the behavior at all? Potentially try running it as a user with more elevated privileges or some other change in context.
  • How do I run it manually?
    There is only one user, me, which is administrator
    There are a few ways. In finder you can navigate to the bin directory of your SDK and try to run the ConnectIQ.app like you would a normal application. Problem with that is no logs are presented to you typically. If you navigate to that directory in a terminal and run either 'open ConnectIQ.app' or './ConnectIQ.app/contents/MacOS/simulator' it might give you a bit more information. Could try running each with 'sudo' prepended to the command as well, see if that changes anything.
  • Same thing, with "open ConnectIQ.app", the connectiq icon flashes up on the task bar at the bottom then disappears, with sudo or not
    "sudo ./ConnectIQ.app/contents/MacOS/simulator" fires it up and it works OK
    "./ConnectIQ.app/contents/MacOS/simulator" fires it up but if I click on it, it closes.
    So what does that mean!?!
    It means that the simulator is trying to do something early on that is deemed by the manager to require elevated privileges. I do not know what that is, and since I am not an expert on macOS I can't say for sure how to check exactly what it is trying to do. Assuming your user account is set up properly, which it probably is, then there seems to be a bug somewhere, potentially in how the simulator is built? Either way, the report seems somewhat similar to what is reported in this thread:
    https://forums.garmin.com/forum/deve...r-not-starting
    Here is a bit of documentation provided by apple on what the simulator might be doing that would require elevated privileges to run:
    https://developer.apple.com/library/...ssControl.html
  • Rupert, you've been doing CIQ for a long time, so maybe you need to look at what changed when this stopped working. Was it a new computer? A new SDK? New Java?
    Something changed when it broke for you, and that might be a clue as to what to look at.
    Did this happen when you moved from 2.3.4 to 2.3.5? Did you move to 2.4.0beta1 (in which case you need a new plugin, and really need a separate eclipse and workspace)
