SDK path and unable to connect to the emulator
Hi All,
I realised there is a weird behaviour of the SDKs (tested with 2.3.4 and 2.4.0 beta 1) using MacOS and Eclipse (I didn't test yet on PCs but I don't believe it will be different).
Installing the SDK on a path which contains blank spaces ("Google Drive" in my case) I'm not able to test the apps into the Emulator. Both from the terminal (using monkeydo) and as well from Eclipse I receive an error message similar to the following: "Unable to connect to the Emulator"
As long as I move the SDK to a different location and I change the path everything works correctly.
Please check and fix it.
Thanks
Fabio
