DeviceSettings.inputButtons does not set bit for down button
o A Descriptive Title (i.e. ?Simulator Freezes Launching App in Eclipse?)
o The Environment:
Windows 10
Eclipse Neon.3 (4.6.3)
ConnectIQ SDK 2.3.4
o A detailed description of the issue
If you run the attached code in the simulator you will see that the bit for the down button isn't being set.
o Steps to reproduce the issue
Build and run the test case. You should see the output shown in the simulator differs from the devices (fr935 and fenix5 are correct, didn't test other devices).
o Any applicable additional information
N/A
o A code sample that can reproduce the issue (in email only if preferred)
See attachment. I can't paste the code into the forums.
