Background -
I'm trying to understand what Position.info.heading actually indicates, and what the limitations of that number really are.
After doing a bit of searching on the forum, I see a number of threads that indicate that the number provided is problematic so app developers have been putting time into "massaging" the number to get something that's more useful in their apps.
I've built and side-loaded the PositionSample app for a bit of testing, and I've loaded and experimented with a Sailing app that provided sources, as well as contacting the developer of that app.
My observations are.....
- The Sailing app uses raw data from Position.info.heading, so changes in reported heading are a direct reflection of the reporting from the Position class.
- In that app, and in the PositionSample app, the heading value does not change for long periods of time at low speeds (walking). I'll be doing more testing.
- Another app, called RaceQs reports heading. That developer has posted here about problems with Position.info.heading, and about reported time of GPS samples, and has stated that coming up with a Course Over Ground that is useful at low speeds takes a lot of massaging of the data.
- The RaceQs app reports meaningful Course over Ground almost immediately and at low speeds.
- All of these tests were done with GPS signal status being shown as GOOD.
Conclusions -
- It looks like there are limitations on the Position.info.heading values and reporting that I cannot find a description of in the API documentation, or on this forum.
- Developers like the RaceQs developer seem to have found that to get meaningful numbers, they have to develop their own substitute for Position.info.heading
Questions -
- What can I, and other developers count on from Position.info.heading ?
- Does the calculation of that value stop below some speed, and if so.... when does it start and stop ?
- Is there a difference between the value reported in Position.info.heading and in Activity.info.heading, or in any other reporting of heading ?
- What is the best, most accurate source of heading information, and what limitations on accuracy are associated with that source ?
After spending some time looking for these answers, I don't find them.
I hope someone at Garmin, or developers who have already been down this road will provide definitive answers.
Thanks
