I just made my first app, and are now working with an update. I have tested the app in the simulator and it works fine, but when I tried it on my Forerunner 235 the watch crash and reboot. The app is a simple scoretracker for disc golf. In the new version I want to be able to track score for up to four persons, but when I add players the device crash on the same place evertime.
When the app starts you see a picture, and the it push a menu where you can choose how many players and holes the round should have.
If you choose one person, the main view is pushed, else a view where you can edit the player names is pushed. In the next view you choose which player you want to track score for and the main view is pushed.
In main view I use up and down for scrolling through the holes, select for pushing the scorepicker and menu for pushing a picker to change the pa value on the hole. Everytime I try to push one of the pickers my device crash, but on the simulator it works.
I found a new problem with the menu button on my Forerunner 235, where the menu button is to press and hold up button. When I try to hold up button my watch it change hole before the picker is pushed, then Im changing the par value on the wrong hole.
I use SDK version 2.3.2
Forerunner 235 Software version 7.40
