I've updated my tutorials to make them compatible with SDK 2.3.2 (especially a lot of changes in the running tests compartment) and also set up a github account for easier management of the accompanied tutorial source code and sample projects, I'll update this topic when I'll add more chapters.
The following tutorials are currently available:
Setup:
Set up the dev environment
Create a data field:
Layout with layouts.xml
layout with dc.draw
using string resources
Unit tests:
Create the unit test project
Run unit tests
Create unit tests
Finished sample projects (as they were submitted to the connect iq store have also made available), at the moment there are 2 projects in the samples folder:
Calculated Field
Steps Carousel
Feel free to discuss the tutorials/sample code below. :)
