Hi Im new to connect iq programming, I want to make an App for the Fenix 5x that can send a message using the generic channel. I have an AntWare stick for listening for ant messages but I can't get the watch to send anything. I only get the BURST_ERROR_TRANSFER_IN_PROGRESS message every time I try to transmit. Any help is greatly appreciated. Below is the code for the Generic Channel provided by Garmin in the sample folder with the sdk.
// Copyright 2016 by Garmin Ltd. or its subsidiaries.
// Subject to Garmin SDK License Agreement and Wearables
// Application Developer Agreement.
using Toybox.Ant as Ant;
using Toybox.System as System;
const ANT_DATA_PACKET_SIZE = 8;
class BurstChannelManager {
const BURST_TX_MESSAGE_COUNT = 50;
hidden var _listener;
hidden var _masterChannel;
hidden var _slaveChannel;
//! Constructor
function initialize() {
_listener = new TestBurstListener();
_masterChannel = new BurstChannel(Ant.CHANNEL_TYPE_TX_NOT_RX, _listener);
_slaveChannel = new BurstChannel(Ant.CHANNEL_TYPE_RX_NOT_TX, _listener);
//! Sends a burst over the master channel
function sendBurst() {
var burst = new Ant.BurstPayload();
for(var i = 0; i < BURST_TX_MESSAGE_COUNT; i++)
// Populate a new burst packet
var data = new [ANT_DATA_PACKET_SIZE];
for(var j = 0; j < ANT_DATA_PACKET_SIZE; j++)
data[j] = i;
// Add the packet to the BurstPayload
burst.add(data);
_masterChannel.sendBurst(burst);
//! Wrapper function that retrieves the current BurstStatistics
//! @return [BurstStatistics] The BurstStatistics gathered by the TestBurstListener
function getBurstStatistics() {
return _listener.burstStatistics;
class BurstChannel extends Ant.GenericChannel {
const DEVICE_NUMBER = 123;
const DEVICE_TYPE = 1;
const FREQUENCY = 66;
const PERIOD_1_HZ = 32768;
const TRANS_TYPE = 0;
hidden var _transmissionCounter;
//! Constructor.
//! Initializes the channel object, sets the burst listener and opens the channel
//! @param [Number] channelType See Ant.CHANNEL_TYPE_XXX
//! @param [TestBurstListener] listener The BurstListener to assign
function initialize(channelType, listener) {
// Get the channel
var chanAssign = new Ant.ChannelAssignment(
channelType,
Ant.NETWORK_PUBLIC );
GenericChannel.initialize(method(:onMessage), chanAssign);
// Set the configuration
var deviceCfg = new Ant.DeviceConfig( {
:deviceNumber => DEVICE_NUMBER,
:deviceType => DEVICE_TYPE,
:transmissionType => TRANS_TYPE,
:messagePeriod => PERIOD_1_HZ,
:radioFrequency => FREQUENCY } );
GenericChannel.setDeviceConfig( deviceCfg );
// Set the listener for burst messages
GenericChannel.setBurstListener(listener);
// Open the channel
GenericChannel.open();
// Reset the transmission counter
_transmissionCounter = 0;
//! Ant.Message handler
//! @param [Message] msg The Message received over the channel
function onMessage(msg) {
var payload = msg.getPayload();
if(Ant.MSG_ID_CHANNEL_RESPONSE_EVENT == msg.messageId)
if(Ant.MSG_ID_RF_EVENT == payload[0])
var eventCode = payload[1];
if(Ant.MSG_CODE_EVENT_TX == eventCode)
//Create and populate the data payload
for(var i = 0; i < ANT_DATA_PACKET_SIZE; i++)
data= _transmissionCounter;
_transmissionCounter++;
//Form the message
var message = new Ant.Message();
message.setPayload(data);
// Set the broadcast buffer
GenericChannel.sendBroadcast(message);
else if(Ant.MSG_CODE_EVENT_CHANNEL_CLOSED == eventCode)
// Reopen the channel if it closed due to search timeout
//! An extension of BurstListener that handles burst related events
class TestBurstListener extends Ant.BurstListener {
var burstStatistics;
//! Constructor.
burstStatistics = new BurstStatistics();
BurstListener.initialize();
//! Callback when a burst transmission completes successfully
function onTransmitComplete() {
burstStatistics.txSuccessCount++;
System.println("onTransmitComplete");
//! Callback when a burst transmission fails over the air
//! @param [Number] errorCode The type of burst failure that occurred, see Ant.BURST_ERROR_XXX
function onTransmitFail(errorCode) {
burstStatistics.txFailCount++;
System.println("onTransmitFail-" + errorCode);
//! Callback when a burst reception fails over the air
function onReceiveFail(errorCode) {
burstStatistics.rxFailCount++;
System.println("onReceiveFail-" + errorCode);
//! Callback when a burst reception completes successfully
//! @param [BurstPayload] burstPayload The burst data received across the channel
function onReceiveComplete(burstPayload) {
burstStatistics.rxSuccessCount++;
printPayload(burstPayload);
System.println("onReceiveComplete");
//! Iterates over a burst paylaod to print each packet
//! @param [BurstPayload] burstPayload The burst data to display
hidden function printPayload(burstPayload)
var itr = new Ant.BurstPayloadIterator(burstPayload);
var payload = itr.next();
while( null != payload )
System.println("payload " + payload);
class BurstStatistics {
var rxFailCount;
var rxSuccessCount;
var txFailCount;
var txSuccessCount;
//! Constructor.
rxFailCount = 0;
rxSuccessCount = 0;
txFailCount = 0;
txSuccessCount = 0;
