Are there any common images for things like a status indicator?
If you are building a watch face, is there a common set of icons for things like Blue Tooth status, Tones on/off, or if there is an Alarm set on the device? It seems having a common icon between watch faces could be a good thing, as if you try a new watch face, you don't want to figure out what a symbol means. Garmin doesn't need to pick one, but maybe the people here can define a set that is the "Common"!
  • If you are building a watch face, is there a common set of icons for things like Blue Tooth status, Tones on/off, or if there is an Alarm set on the device? It seems having a common icon between watch faces could be a good thing, as if you try a new watch face, you don't want to figure out what a symbol means. Garmin doesn't need to pick one, but maybe the people here can define a set that is the "Common"!
    +1
    Likewise for GPS accuracy, etc
  • We don't have a common set of icons that we make available I am aware of, but I think this is a good idea. I know I would prefer to at least have a basic set on hand as part of the SDK that I could use, and then customize if I choose. I'll file a request to have this considered for addition to a future release.
    Sounds good.
    It would be even better if (some of) these icons could be referenced directly without adding them to an application - and thus saving precious space for the apps :-)
  • In my proposal, I suggested a design where the indicators are included as part of the built-in fonts and could be used in a similar fashion to font resources. That would allow a lot of flexibility in sizing and colors, and not require the designer to load additional graphics. We'll see what happens. :)
  • Ithe indicators are included as part of the built-in fonts and could be used in a similar fashion to font resources.
    Yes. This seems like the best way to implement it since you can get any color icon you want (two colors only), with a single resource. I use a custom font for this in my watch face already (the character V maps the vibrate on icon, v maps to vibrate off, ...).
    Travis
    Former Member over 10 years ago
    Font would be a win, it's how I sourced most of my icons (well, at least ones that aren't drawn using primitives).
  • Here is the list that comes to mind. Maybe too many and some I missed!
    Alarm - watch alarm on/off
    Blue tooth - on or off
    Battery - (the percent could then be next to it)
    Clock - something like "12h" or "24h" in the same space as the others.
    Goal - below/above images for step activity goal
    GPS - on or off
    Notifications - new/no new ones
    Low Power - on or off
    Would also be nice to have some common "screens" (images or complete layouts) especially when dealing with errors or system requirements. For instance, my widget requires a bluetooth connection and I'd like to display the same "Garmin Connect Mobile Connection Required" screen as the Garmin apps do.
  • Thanks for the suggestion--I've added your idea to the request. The things we've discussed in this thread have been prioritized on the road map, so we'll be working on getting this included in a future release.
