I'm having problems to work with BLE Simulation Over Android Debug Bridge. The compiler doesn't recognize IQCommProtocol. Am I missing something very obvious? Some class I should import or so? Could someone provide me with a working example?
According to the documentation:
"To enable the companion to communicate over ADB you must:
1. Connect the phone to the PC running the simulator via USB.
2. Have USB debugging enabled on the Android handset.
3. Obtain an instance of ConnectIQ using getInstance(IQCommProtocol.ADB_SIMULATOR)
4. Optionally call setAdbPort(int port) to set a specific port to use for communication. The default port is 7381.
5. Call initialize().
To allow the simulator to communicate over ADB, in a terminal or console forward the tcp port you are using to the Android device.
adb forward tcp:7381 tcp:7381"
PS: I'm working with Android Studio on a Mac.
