Testing beeps...
Hello all
When I develop an app that use the speaker for notification I was allways wasting time testing each sound available in ConnectIQ. That's why I developped a (stupid) app that allow you to choose and play any of the available sounds..
It has been approved today by Garmin and is available here : https://apps.garmin.com/en-US/apps/a32959dc-15fd-4399-89ec-91889009cb8f
Hope this will help you too ;-)
Regards
  • not released yet and already a feature request :)
    maybe you can extend the app with a vibration-length+strength setter to test that as well :)
    Queretaro hacienda
    That's the next one I planned to release ;-)
    You read my mind....
  • just tried it, the up/down keys don't work on my device (fr735xt), start button works and plays the tone.
  • If you include vibrations, another thing to note is not all watches support tones and vibrations. The va and va-hr only support vibrations, and things like the Edges, Oregon, and Rino, only tones.
    Maybe in the app show if one or the other, or both are supported?
    Just tested it on the simulator and the keys are working... I don't have a "real" forerunner to test it :-( Any hint ? I use the following code :
    [FONT=Courier New] function onKeyReleased( evt )
    var key = evt.getKey();
    if( key == KEY_UP )
    viewControler.viewUp();
    return true;
    if ( key == KEY_DOWN )
    viewControler.viewDown();
    return true;
    if ( key == KEY_ESC )
    System.exit();
    return true;
    return false;
    }[/FONT]
    Strange as it works on the simulator for that watch. Unfortunately I don't own one and can't test "for real". Here's the code I use. Any idea ?
    Regards
    [FONT=Comic Sans MS] function onKeyReleased( evt )
    if( key == KEY_UP )
    return true;
    return true;
    System.exit();
    return true;
    return false;
    }[/FONT]
  • Try using onKey() instead of onKeyReleased()
    onKeyPressed() and onKeyReleased() are kind of "odd" on some devices.
  • not sure why the onkeyreleased would not work, in my starttorun app I use the onKey event:
    function onKey(key) {
    var evt = key.getKey();
    if (evt == Ui.KEY_ENTER) {
    } else if (evt == Ui.KEY_UP) {
    } else if (evt == Ui.KEY_DOWN) {
    } else if (evt == Ui.KEY_MENU) {
    maybe that works better?
    Just changed to onKey and republished it.... Please let me know ;-)
    Regards
    I was able to test it out on the 735 and the up and down keys are working now.
    Thanks,
    -Coleman
