Hi,
I have a problem with my watchface (SAPPY) crashing with users owning a FR935 and a Fenix 5 watch.
On for instance the FR235 and Fenix 3HR it works fine.
From several F5 users I understood that it crashes when after an activity has started or after 15s after it has been installed.
I also got the CIQ_LOG.TXT files from these users:
ERROR: Unexpected Type Error
DETAILS: Failed invoking <symbol>
STORE_ID: 5372fc74469b48468dec60dd7997e909
CALLSTACK:
@PC = 0x1000573f
In the simulator from Eclipse Neon 3 with CIQ SDK 2.2.6 all works fine.
RAM usage is about 41kb peak.
Searching around for this particular error does not lead to a satisfying answer.
Perhaps someone can help me out?
PS. when i have uploaded a new version to the connect iq store and I try to update it with my app and my watchface is installed, "error trying to delete". Then I select another watchface and then it will update normally. But when I select the watchface again all settings have been overwitten with the defaults values? Is this normal? A few months ago it worked flawless?
Thanks.
