Is there any way to test this properly? I can only see publishing the app and then testing if it works but that's pretty crappy and also involves uploading many test versions.
CIQ_LOG.TXT gives this:
ERROR: Unhandled Exception
DETAILS: NONE
STORE_ID: d3bdae89b70740408ea84c55f9a81168
CALLSTACK:
UnexpectedTypeException: Expected Number, given Long
I now caught all getProperties to check for null values and non number but that results in it loading the default values all the time... (So apparently it doesn't pass those checks, but I can't figure out why).
I added the <APPNAME>.TXT file in the LOG folder as well but don't see too much extra info.
But the entire process sucks, connecting watch to pc, disconnect, or sync by bluetooth. Rinse and repeat...
Is there any easier way to do this?
For completeness part of my code:
properties.xml:
<properties>
<property id="BackgroundColor" type="number">0xFF0000</property>
<property id="ForegroundColor" type="number">0xFFFFFF</property>
<property id="UseMilitaryFormat" type="boolean">false</property>
<property id="AmPm" type="boolean">false</property>
<property id="Invert" type="boolean">false</property>
<property id="Field1" type="number">1</property>
<property id="Field2" type="number">2</property>
<property id="Field3" type="number">3</property>
<property id="Field4" type="number">4</property>
<property id="Field5" type="number">5</property>
<property id="Field6" type="number">7</property>
</properties>
settings.xml
<setting propertyKey="@Properties.UseMilitaryFormat" title="@Strings.MilitaryFormatTitle">
<settingConfig type="boolean" />
</setting>
<setting propertyKey="@Properties.Field1" title="@Strings.Field1Title">
<settingConfig type="list">
<listEntry value="0">@Strings.None</listEntry>
<listEntry value="1">@Strings.Steps</listEntry>
<listEntry value="2">@Strings.Cals</listEntry>
<listEntry value="3">@Strings.Dist</listEntry>
<listEntry value="4">@Strings.Bat</listEntry>
<listEntry value="5">@Strings.Sunrise</listEntry>
<listEntry value="6">@Strings.Sunset</listEntry>
<listEntry value="7">@Strings.Goal</listEntry>
<listEntry value="8">@Strings.ActMin</listEntry>
</settingConfig>
</setting>
<setting propertyKey="@Properties.Invert" title="@Strings.InvertTitle">
</setting>
<setting propertyKey="@Properties.AmPm" title="@Strings.AmPmTitle">
</setting>
strings.xml:
<string id="InvertTitle">Invert Color Scheme</string>
<string id="AmPmTitle">Use AM/PM for Time</string>
<string id="Field1Title">Top-Left Field</string>
<string id="Field2Title">Top-Right Field</string>
<string id="Field3Title">Mid-Left Field</string>
<string id="Field4Title">Mid-Right Field</string>
<string id="Field5Title">Bottom-Left Field</string>
<string id="Field6Title">Bottom-Right Field</string>
<string id="None">None</string>
<string id="Steps">Steps</string>
<string id="Cals">Calories</string>
<string id="Dist">Distance</string>
<string id="Bat">Battery</string>
<string id="Sunrise">Sunrise</string>
Program code:
var invert = App.getApp().getProperty("Invert");
var ampm = App.getApp().getProperty("AmPm");
if(invert==null || !(invert instanceof Number)){invert=false;}
if(ampm==null || !(ampm instanceof Number)){ampm=false;}
//var ampmString = "";
var f1 = App.getApp().getProperty("Field1");
var f2 = App.getApp().getProperty("Field2");
var f3 = App.getApp().getProperty("Field3");
var f4 = App.getApp().getProperty("Field4");
var f5 = App.getApp().getProperty("Field5");
var f6 = App.getApp().getProperty("Field6");
if(f1==null || !(f1 instanceof Number)){f1=1;}
if(f2==null || !(f2 instanceof Number)){f2=2;}
if(f3==null || !(f3 instanceof Number)){f3=3;}
if(f4==null || !(f4 instanceof Number)){f4=4;}
if(f5==null || !(f5 instanceof Number)){f5=5;}
if(f6==null || !(f6 instanceof Number)){f6=6;}
App.getApp().setProperty("BackgroundColor", 0x000000);
App.getApp().setProperty("ForegroundColor", 0xFFFFFF);
var bgColor = App.getApp().getProperty("BackgroundColor");//Gfx.COLOR_BLACK;
var fgColor = App.getApp().getProperty("ForegroundColor");//Gfx.COLOR_WHITE;
if(bgColor == null || !(bgColor instanceof Number)){bgColor = 0x000000;}
if(fgColor == null || !(fgColor instanceof Number)){fgColor = 0xFFFFFF;}
if(invert){
bgColor = App.getApp().getProperty("ForegroundColor");//Gfx.COLOR_WHITE;
fgColor = App.getApp().getProperty("BackgroundColor");//Gfx.COLOR_BLACK;;//Gfx.COLOR_BLACK;
