How do you hide seconds when going into sleep? I am using dc.drawText to display seconds (as it is more flexible then using the resources and I have tried setting a boolean on onEnterSleep and on onExitSleep and using this value in the onUpdate function to hide or show, but it isn't working. Any thoughts?
When you enter sleep mode, set the Boolean you have to indicate to not draw the seconds, then call Ui.requestUpdate(). In your onUpdate() function, check the Boolean and skip drawing the seconds.
