Hi,
I want to implement an indicator in my datafield in which direction the beginning of the activity is. I searched in the activity.info field and found bearingFromStart. The api doc says:
bearingFromStart is the direction of desired track from start of navigation to destination in radians. This is only dependent on your location when the Course is set, and it is not dependent on where you may have moved to.
Is this the information I can use?
