In your delegate, in general, what you return indicates what you want the firmware to do.
Jim is correct here. Based on the pictures you provided, you are looking at the native (built-in) heart rate widget. This is built into the system software and can take more direct control of the hardware than Connect IQ can. The interface you are seeing is the "Broadcast Mode" on the device. This broadcasts the HR data using the ANT+ chip on the device. Unfortunately, Connect IQ widgets do not have the ability to override the time-out limitations for battery saving purposes. Hopefully this will clear things up a little for you.
Thanks so much,
-Coleman
I don't have that watch, but as I said, on a fenix 5 it does time out. But it really doesn't matter, as it's a native widget, and isn't written in Connect IQ. CIQ widgets on watches will always time out, and there is no way to avoid that.
