The steps they're doing are:
- download Simple datafield
- field works OK with default settings
- update & sync settings via express
- settings retrieved all null
After using the user's SET file on my 735XT & Edge 820, it does indeed retrieve null values.
Does anybody know how to debug this, or the SET file ( i compared the hex but couldn't see anything obvious, i assume this is some kind of serialized c object?)
I currently don't use loadProperties, but I was thinking if this is an old 1.2 SDK device it may require it (although, that wouldn't explain why their SET wouldn't work on mine), but then again i'm clutching at straws now!
Any tips would be appreciated!
