monkeyc -e.
When I restrict the minimum SDK to 1.4.0., I'm getting the following printed out as a result.
Is there any way I can find what code matches the given "part numbers"?
WARNING: Part number: '006-B2293-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2188-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2189-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2407-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2408-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2467-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2160-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2313-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2310-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2311-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2733-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2653-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2396-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2397-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2132-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2130-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2131-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
WARNING: Part number: '006-B2473-00' is being ignored by the package tool because it does not support the minimum SDK version set for this project
