Publishing without Eclipse
Hello folks, I'm new here, tried to search for this information but no luck, so asking...
I developed a weather widget for my Vivoactive HR, since the original one did not provide accurate weather information here in Italy, so I wrote one using the Yahoo Weather API. I managed to develop everything without touching Eclipse in the process, only using the command line tools. However now that I'm about to publish my application, apparently I should use the "App Export Wizard" in order to generate the final file to submit. After I went so far without Eclipse, I would like to continue and do this final step without using an IDE. Is that possible? Thank you.
