Is there anyway to influence/set the font sized used for a menu title?
I have a menu where I dynamically change the contents of the menu title each time it is viewed (shows an elapsed time, in this case). I've had several users complain that the font is too small to read and given all the space the menu title area takes up, I could easily afford to use a larger font. However, I can't see if/where I can do that. I only set the setTitle and addItem, but cannot see a way to influence the menu title font size.
Thee menu contents themselves are static and the menu is defined in a resource via menus.xml. Only the title change and would benefit from a larger font.
This is on a FR235, if it matters. Any one have any suggestions?
Thanks,
Gerry
