I need to do something very simple without having to write the code for an entire app. I've created a ConnectIQ Data Field which can easily be added to the pre-existing Garmin Run activity to show ANT+ sensor Power in watts from a force sensor in the running shoe, just like you would inside the Bike activity if you were riding with an ANT+ power meter. This combination with the Run activity allows combination of watts with Running Dynamics fields already available from the Garmin run strap. It works just find for display on the watch, but does not save to the pre-existing .FIT file generation within Garmin's own Run activity. Of course, it can work with the Bike app and save the power in watts, but then the running dynamics are not available there.
Is there any way to use the FitContributor module to simply add this additional Power field to all the other ones already being recording in the Run activity .FIT file? I know you can do this by writing a complete app like the Moxy Sample, but this is for lots of fields in a truly unique configuration and I just need to add one field to the one-second record for power in watts.
It says in the documentation that FitContributor works for a Data Field and App, but it does not say a Data Field WITHOUT creating a custom Watch App.
Any thoughts? Great stuff in the forum on how to use FitContributor with Apps like Moxy sample, but not something simpler. Before I try it on my own, to strip Moxy way down to work as a Data Field for only one value, I'd like to know if it's even possible.
Thanks,
Ironman.Texas
