Hey there,
I haven't got deep into the Monkey C API, I'm a beginner programmer
with experience in coding using mostly C# & Java languages.
My Question is: how difficult it is to get into coding a simple app
in Monkey C?
Thanks in advance.
Have you looked at the samples in the SDK and installed the environment? (some aren't fans of Eclipse, but that's what I've used since day 1).
The Programmer's guide takes you through the setup, as well as shows you how to use the template for a watch face and get your own very basic one done in just a few minutes. (you can do the same with a widget,data field, or watch-app too).
After that, it really depends on what you want to do. The samples show you how to do a number of different things, such as an analog watch face, do comm, record a .fit, etc.
- Simulator doesn't actually behave same as watch (at least not same as vivoactive, my device)
What kind of things are you seeing?
