Headers in Communications request
I try to implement a very simple Garmin Connect IQ app that downloads some tiny json data from a webservice. Webservice authentication is HTTP basic.
I try to implement it like this:
var authString = StringUtil.encodeBase64("someusername:somepassword");
authString = "Basic " + authString;
Comm.makeWebRequest(
"somewebserviceurl,
"Headers" => { "Authorization" => authString }
method(:onReceive)
It does not fetch the response, responsecode is 0, so it is not informative at all. If I try calling any webservice that does not need any authentication, it works, so the problem is the basic authentication.
What can be the problem? Thanks very much in advance!
  • There are two issues with your code.
    • the key in the options map is :headers, not "Headers". The former is a symbol and the latter is a string (see the docs).
    • you should specify your request parameters in the params parameter.
    var url = "somewebserviceurl";
    var params = {
    "param" => 1
    var options = {
    :headers => {
    "Authorization" => "Basic " + StringUtil.encodeBase64(Lang.format("$1$:$2$", [ someusername, somepassword ]))
    Comm.makeWebRequest(url, params, options, method(:onReceive));
    Thanks a lot, it works! :)
