Cannot access app settings from a copied project
Hi,
I have created a watchface which works pretty well regarding passing settings via the "App Settings Editor". I created a new connect IQ project and copied all the code to the new project's class. Then I copied the ressources.xml file.
By doing this I can't pass any setting value to the new copied watchface - the editor just shows an empty rectangle. I then removed all the code again and streamlined the ressources.xml a lot just to try if the editor shows only one setting. But it shows only an empty rectangle.
Any ideas what causes the problem?
Thanks for supporting.
