Hi,
I’m developing an unpublished Connect IQ watch face and testing it locally on my own watch. It is not available in the Connect IQ Store.
I’m trying to understand the correct lifecycle handling for restarting an animation after returning to the watch face.
Environment recorded in the attached device log:
tactix 8 51 mm AMOLED, device family
fenix847mm -
Firmware 23.40
ConnectIQ API 6.0.3
ConnectIQ runtime 6.0.2
Animation works after a wrist gesture. However, occasionally, after reading a notification (and pressing BACK to return to the watch face, a brief IQ error icon appears. The watch face then resumes without further interaction.
The device log records:
Error: Permission Required
Details: "Symbol 'animate' not available to 'Watch Face'"
The failing call path is:
onShow() → startLifecycleAnimation() → WatchUi.animate()
Before calling animate, my code checks that the display is HIGH, Application.getApp().isActive() is true, and the face is outside its known settings/editor/preview contexts. A catch for Lang.Exception does not intercept this failure.
One assumption in my current code may be wrong: onShow() derives a local sleeping flag from the display mode. I do not know whether a HIGH display necessarily means that the watch face itself is permitted to animate.
Could you clarify:
Is there a supported way to check whether a watch face currently has permission to call
animate, independently of display mode andisActive()? -
What is the correct callback or pattern for restarting animation after returning from notifications or another screen when no new OS
onExitSleep()callback occurs? -
If restarting is not supported in that situation, should the face remain at the normal update rate until the next genuine wake event?
I’m not manually invoking onExitSleep(). Active animations are cancelled on hide, sleep and app-inactive transitions.
I’ve attached selected device-log entries with local paths and app identifiers omitted, plus an abridged code excerpt. The excerpt is not a standalone reproduction. The failure is intermittent on the physical watch.
I’m looking for guidance on the supported API behavior, rather than assuming this is a firmware bug.
Thank you.
Relevant entries transcribed from the device log.
Local Windows paths and application identifiers are omitted. These are selected log fields, not an unchanged copy of the complete original log.
Device: tactix 8 51 mm AMOLED (CIQ family fenix847mm)
Firmware-Version: 23.40
ConnectIQ-API-Version: 6.0.3
ConnectIQ-Version: 6.0.2
Time: 2026-11-15T07:18:02Z
Stack (function names and source line numbers):
startLifecycleAnimation — line 306
onShow — line 241
Time: 2026-11-15T08:06:08Z
onShow — line 241
ABRIDGED MONKEY C CODE EXCERPT — UNPUBLISHED DEVELOPMENT WATCH FACE
Based on the methods reviewed during debugging. Rendering/cache work and some diagnostics are omitted. This is not a complete, buildable reproduction.
The app-owned fields below are local bookkeeping, not native permission values.
NativeFaceConfig.preview is an app-owned flag read from :launchedFromWatchFaceSettingsEditor at startup.
function onShow() {
settingsOpen = false;
var showMode = System.getDisplayMode();
visible = true;
if (!animationRunning) {
sleeping = showMode != System.DISPLAY_MODE_HIGH_POWER;
// Rendering/cache setup omitted.
startLifecycleAnimation(false, "Show");
WatchUi.requestUpdate();
function startLifecycleAnimation(genuineWake as Lang.Boolean, origin as Lang.String) as Void {
if (animationRunning || !smoothSeconds || settingsOpen || editorActive || NativeFaceConfig.preview) {
return;
if (!RenderState.mayAnimate(visible, sleeping, System.getDisplayMode())) {
return;
if (!genuineWake) {
if (returnStartAttempted || returnStartDenied) { return; }
var app = Application.getApp();
if (!(app has :isActive) || !app.isActive()) { return; }
returnStartAttempted = true;
animationAllowed = true;
pendingAnimationStart = false;
try {
WatchUi.animate(self, :animationPhase, WatchUi.ANIM_TYPE_LINEAR,
0.0, 1.0, 300.0, null);
animationRunning = true;
} catch (error instanceof Lang.Exception) {
animationRunning = false;
animationAllowed = false;
returnStartDenied = true;
// Ordinary-exception reporting omitted.
// Diagnostics omitted.
module RenderState {
function mayAnimate(visible, sleeping, mode) {
return visible && !sleeping && mode == System.DISPLAY_MODE_HIGH_POWER;
Relevant surrounding lifecycle behavior:
- Actual OS onExitSleep calls the helper with genuineWake=true.
- App onActive also calls this helper with genuineWake=false and origin="Active".
- Active animations are cancelled on onHide, onEnterSleep and app onInactive.
- The recorded failing stack is onShow -> startLifecycleAnimation -> animate.
Question: deriving sleeping from display HIGH in onShow may be an incorrect assumption. What supported lifecycle pattern should replace this to restart an animation after returning without a new OS onExitSleep, if that is supported?
