Hi everyone,
I’m developing a Connect IQ watch app that uses Communications.makeImageRequest() to load public map PNG tiles over HTTPS.
Instinct 2 series users have reported that the map never appears and the watch repeatedly shows “Map timed out.” One tester was on Android mobile data with Garmin Connect open and battery saver disabled.
The app requests one tile at a time. It asks Garmin to resize the image to at most 192 × 192 pixels and convert it to a black-and-white palette. If no callback arrives within 20 seconds, OpenMaps cancels the request. The latest build distinguishes two cases:
- “Garmin code: -300” means the image request callback returned -300.
- “No reply after 20s” means OpenMaps reached its own timeout without a callback.
In the Connect IQ simulator (9.3.0), the same live tile requests usually succeed, including with the PC connected through an iPhone hotspot. I’ve seen an occasional missing callback in the simulator, but I haven’t reproduced the repeated failure users are seeing on physical watches.
If you’d like to test it yourself:
apps.garmin.com/.../f5cd5919-84f9-41b3-b5c7-276a154039bc
Open Garmin Connect on your phone, then open OpenMaps on the watch and hold MENU → Test online maps. This requests a single live tile from a fixed location and works indoors without a GPS fix. If possible, try once with your phone on Wi-Fi and once on mobile data.
I'm curious if anyone has seen makeImageRequest repeatedly fail or go without a callback on these devices? Is there a Garmin-side diagnostic that can help distinguish an image-service failure from a problem delivering the bitmap back to the watch? On Insinct 3 watches, the method works fine.
