Does anyone know if personal API key has the Avg skin temp change data? if so how can we read it?
Can anyone help me please? Looking for avg skin temp change data
What is the exact endpoint name or address?
For example, anything with "skinTemp" in it under the Health or Wellness section.
Sensor.Info.temperature is usually the devices internal temperature unless a tempe is connected. It may be off from the skin temperature because of the ambient temperature. If the device doesn't have a baro altimeter, you won't get a reading as the temperature sensor is part of that.
Thank you. please see the attached screenshot. It shows in Connect under sleep score. Does personal API key pulls this data (avg skin temp change) ?
