Datafield 3S Power
I'm trying to build a custom datafield screen, and was looking to pull in the 3s PWR value from the Activity module. Does anybody know how to obtain this value? Or calculate it from info.currentPower?
  • If you just want three second average power, you can store the last three power values and average them. I'm just throwing this code out there, it may not be perfect..
    class XDataField extends Ui.SimpleDataField
    hidden var _M_samples;
    function initialize(seconds) {
    SimpleDataField.initialize();
    _M_samples = new [seconds];
    _M_index = 0;
    _M_count = 0;
    function compute(info) {
    if (info.currentPower == null) {
    return null;
    _M_samples[_M_index] = info.currentPower;
    _M_index = (_M_index + 1) % _M_samples.size();
    if (_M_samples.size() != _M_count) {
    _M_count += 1;
    var sum = 0.0;
    for (var i = 0; i < _M_count; ++i) {
    sum += _M_samples;
    return (sum / _M_count).toNumber();
    [/code]
    I think the following is another reasonable way to implement it, but it is a filtered value (it won't change as quickly as the one above).
    hidden var _M_seconds;
    hidden var _M_average;
    _M_seconds = seconds;
    return null;
    if (_M_average == null) {
    _M_average = info.currentPower;
    else {
    _M_average = ((_M_average * (_M_seconds - 1)) + info.currentPower) / (_M_seconds * 1.0);
    return _M_average.toNumber();
    You may have to implement the timer callback functions (onTimerStop(), onTimerPause(), onTimerReset()) to finish this, but the above should be a good start.
    Travis
    _M_index = 0;
    _M_count = 0;
    return null;
    _M_count += 1;
    var sum = 0.0;
    sum += _M_samples;
    [/code]
    return null;
    else {
    _M_average = (_M_average + _M_average + info.currentPower) / 3.0;
    Travis
    This is really helpful, thank you very much!
  • Note that I had an error in the second implementation. It should now work with different duration values as the constructor implies.
    Travis
