Solved. Developer found. Thank you everyone.
Hi Luca,
Custom, clean-slate watch faces tailored specifically to these requirements are completely feasible to develop.
Developing for the Instinct 3 AMOLED requires efficient Monkey C implementation via the Garmin Connect IQ SDK to ensure high-resolution layouts scale properly without causing screen burn-in or high battery consumption.
Directly reproducing or cloning an official, proprietary Garmin watch face design can introduce legal and compliance risks regarding intellectual property rights. To navigate this safely, the best approach is engineering a custom architecture from scratch that is heavily inspired by those visual layouts but distinctly original. This makes it simple to handle all the underlying data syncing (Time, Battery, HR, Steps), expose clean configuration properties, and ensure full source code delivery and total project ownership. This makes it easy to modify labels, boundaries, and text fields down the road.
Thoughts ? Does this align ? thanks
No worries, if it falls through re-post on here, as I would be interested and I'm sure others would be too
