Group option in the settings doesn't work correctly when you use a settings with date format. Only on physical watch, correct in simulator
When in the settings, you use group option and when in this group you have a field of date format, the field display an error and you can't exit correctly the setting.
It's appear only on physical watch but its good in simulator
To reproduce the bug.
Define a simple watch face with settings. and add 2 informations
In the display with garmin connect on your phone , you can't see the correct date. and you can't save it because it's empty
<properties xmlns:xsi="">www.w3.org/.../XMLSchema-instance" xsi:noNamespaceSchemaLocation="">developer.garmin.com/.../resources.xsd">
<property id="BackgroundColor" type="number">0x000000</property>
<property id="ForegroundColor" type="number">0xFF0000</property>
<property id="UseMilitaryFormat" type="boolean">false</property>
<property id="CDown" type="number">1798758000</property>
</properties>
<settings xmlns:xsi="">www.w3.org/.../XMLSchema-instance" xsi:noNamespaceSchemaLocation="">developer.garmin.com/.../resources.xsd">
<setting propertyKey="@Properties.BackgroundColor" title="@Strings.BackgroundColorTitle">
<settingConfig type="list">
<listEntry value="0x000000">@Strings.ColorBlack</listEntry>
<listEntry value="0x555555">@Strings.ColorDarkGray</listEntry>
<listEntry value="0xAAAAAA">@Strings.ColorLightGray</listEntry>
<listEntry value="0xFFFFFF">@Strings.ColorWhite</listEntry>
</settingConfig>
</setting>
<group id="groupAppear" title="@Strings.groupAppear" description="@Strings.groupAppearDescription">
<setting propertyKey="@Properties.ForegroundColor" title="@Strings.ForegroundColorTitle">
<listEntry value="0x0000FF">@Strings.ColorBlue</listEntry>
<listEntry value="0xFF0000">@Strings.ColorRed</listEntry>
</settingConfig>
</setting>
<setting propertyKey="@Properties.UseMilitaryFormat" title="@Strings.MilitaryFormatTitle">
<settingConfig type="boolean" />
</setting>
<setting propertyKey="@Properties.CDown" title="@Strings.CDown"><settingConfig type="date" required="true"/></setting>
</group>
</settings>
