Hi,
when starting my app on a CIQ 3.4 device with 32 kB glance memory, such as the Fenix 6 Pro or Forerunner 945 LTE, I get an Out of Memory Error: Failed loading application.
The error occurs before the glance is started. AppBase.getGlanceView() has not been executed yet. The stack trace points to a seemingly random file that is not even part of the glance scope.
When I start the glance on a device with 64 kB glance memory, it only uses 13 kB of memory, with a peak usage of 15 kB. So this does not really seem to be caused by a lack of memory.
What else could cause such an error?
Here is the error message:
Error: Out Of Memory Error
Details: Failed loading application
Stack:
- at D:\GitHub\ohg\source\main\data\communications\connection\RequestUiUpdateTask.mc:11 0x80000000
Encountered app crash.
For reference, here is the code base, including the file the error points to:
