Hi,
I’m trying to understand the expected GPS simulation behavior in the Connect IQ Simulator on `fr265`.
I have a normal `watch-app` with:
```monkeyc
Position.enableLocationEvents(Position.LOCATION_CONTINUOUS, method(:onPosition));
Then in the simulator I use:
Settings -> Set Position
Settings -> Set GPS Quality
What I can confirm:
these menu items do change the current position state
Position.getInfo() reflects the new values
What I cannot get:
my app does not receive any onPosition() callback
this happens not only in my app, but also in a very small sample-style app that subscribes in onStart()
So the simulator appears to change the location state, but not deliver it as a location event callback to the app.
Environment:
device: fr265
app type: watch-app
Positioning permission is enabled
simulator menus are available
tested with LOCATION_CONTINUOUS
My question is:
For a normal watch-app on fr265, what is the correct way to make the simulator generate actual Position.enableLocationEvents() callbacks?
Is Set Position / Set GPS Quality only meant to affect Position.getInfo() state?
Or is there another simulator mode / activity / switch that must be enabled first?
Thanks.
