Hi,
I have issue where my Windows 8.1 Machine can't connect to the simulator. I took a break of about 8 months from development, where I could connect before. I had a previous post on here, but I dropped the ball on that one. (https://forums.garmin.com/showthread.php?364672-Couldn-t-connect-to-simulator).
I have installed Eclipse Neon.2, and the Connect IQ software. I still have issues connecting to the simulator as in my previous post. I have rolled back to an older version of the SDK, and it gives up after 5 attempts. I tried doing 'blind development', but I seem to get a run-time error on my Fenix 3 where the bitmap won't load to the background. I need to use the simulator to see what is happening.
Please assist,
Warm Regards, Greg.
BUILD: WARNING: The launcher icon 'LauncherIcon' (30x30) is smaller than the specified launcher icon size of the device 'square_watch' (61x43). Padding will be added to the image to center it.
BUILD: Complete
BUILD: C:\Program Files\Java\jre1.8.0_65\bin\java -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar "C:\Garmin SDK\connectiq-sdk-win-1.2.5\bin\monkeybrains.jar" -a "C:\Garmin SDK\connectiq-sdk-win-1.2.5\bin\api.db" -i "C:\Garmin SDK\connectiq-sdk-win-1.2.5\bin\api.debug.xml" -o C:\Projects\Garmin2\13_Faces_Mk2\bin\13_Faces_MK2.prg -w -z C:\Projects\Garmin2\13_Faces_Mk2\resources\drawables\drawables.xml;C:\Projects\Garmin2\13_Faces_Mk2\resources\layouts\layout.xml;C:\Projects\Garmin2\13_Faces_Mk2\resources\strings\strings.xml -m C:\Projects\Garmin2\13_Faces_Mk2\manifest.xml -u "C:\Garmin SDK\connectiq-sdk-win-1.2.5\bin\devices.xml" -p "C:\Garmin SDK\connectiq-sdk-win-1.2.5\bin\projectInfo.xml" C:\Projects\Garmin2\13_Faces_Mk2\source\_Faces_MK2View.mc C:\Projects\Garmin2\13_Faces_Mk2\source\_Faces_MK2App.mc -d fenix3_sim
BUILD: WARNING: The launcher icon 'LauncherIcon' (30x30) is smaller than the specified launcher icon size of the device 'fenix3' (40x40). Padding will be added to the image to center it.
BUILD: Complete
Attempt 1 to connect to simulator...
Attempt 2 to connect to simulator...
Attempt 3 to connect to simulator...
Attempt 4 to connect to simulator...
Attempt 5 to connect to simulator...
Couldn't connect to simulator.
